I am reacthing out for some help/tips at troubleshooting on my C3 Syncrodrive.
I have been running the Syncrodrive on my 13 M800 for some years without issues, and this season I decided to switch the Syncrodrive over to my dragsled 12 XF 1100 turbo, and having problems now.
Installed it with a SSI/BDX Titanium jackshaft and new SKF 2206 bearings (sealed and self alignment) in both ends. And new SKF sealed 6009 bearings in both ends of driveshaft.
Did also replaced my motor mounts with some adjustable polyurethane mounts from Hi-tech Engineering, and then adjusted/aligned the engine/clutch parallelism to 1mm.
Machineered a shim behind the hub (top gear) and made sure that the gears was aligned too.
The problem comes when I ride it, when going at steady speed or low resistance the belt is sitting perfect at the gears. BUT as soon as I go harder on the throttle and the resistance/load from the track is rising, the belt is going more and more side ways out on the top gear.
Did have a couple of "holeshot/take offs" and the belt smacked the guide plate so hard that it bent, as you see in the pictures.
I'm very frustrated because I dont see the issue that makes my belt to do that.
I appreciate every help!
