Belt deflection
Having a problem with my pdrive. When I torque it down it squeezes the belt too far and I can’t properly set my deflection. I have to run the belt about 1/4” lower in the secondary than it’s supposed to be or the sled creeps bad. Anyone know the fix for this? Sled is a 2017 850 165X3. Dynamo Joe clutch kit.
Can you post pictures of everything?
It’s on right. I’ve pulled it several times double checking. I’ll post some pics when I get home. It’s fine until I torque it. Then it’s like the dampener is going too far into the taper and I lose belt to sheave clearance.
Did you install the new 2019 motor mounts?
If so you have one of the motor mounts installed upside down.
if the belt is too low it will creep forward, that's normal. I think you're looking at it backward
Sent from my LG-H873 using Tapatalk
