Belly Buster
Seabass152
Tried searching and posting in the clutching section but no luck. Will I need to re-shim if I switch from 10 series Polaris weights to Belly Busters?
Thanks
I tried 62 gram belly busters in mine and had way to much clearence around so i went back to the mtx witch are around .015 on my sled.
BellyBusters are the same initial profile so installing them will be the same belt clearance as the stock 10 series... but that doesn't mean that stock clearance is right. Almost every clutch I have seen needs to be tightened up.
sled_guy
