There is a guy on dootalk.com that sells an insert that works great. I think his name is Dan. I used it on my '04 Rev and it worked perfectly. Didn't cost much either. His username is DAN03REV. Try this link http://www.dootalk.com/forums/index.php?showtopic=127154&st=375
quick fix is to switch the gas cap with the oil cap
X2...he has model for XP's also.
I love it.............. classic.........
Ski-doo leaks..........buy polaris parts.......
I'm sorry AC has there issues too but thats funny
Are you sure it is the cap? I had a leak and put 3 differant caps on trying to solve the problem. Turned out to be that the neck of the tank was cracked abou a 1/4 of the way around, probably from tightening the cap to tight. A new tank solved the problem and now I just turn the cap down till it stops, no more than that. The crack should be easy to see, as it shows up as a slightly darker hairline in the plastic, because it fills with oil.
