flexible cracking..........oh crap
I built three kits using spherical self centering bearings like Arctic cat and POlaris used for 20 years. This setup allows for some sideplate flex without overstressing the bearing. I had to routinely replace my bearing, side stress is always the issue, they will run dry a long time as long as you are not stressing the bearings with side loads.
Out of the box on any of the kits, any possible side load stress on the bearing from inconsistency in manufacture fitting will take out bearing real fast. The new 18 TS kits will be a step towards minimizing that due to CNC parts as opposed to jig welded frames that are not all the same..............as brakes don't always work.
The kit I built and rode the most I added two cross bars a head of the track, side plate to side plate to cut down on side flex. I added a welded in brace behind at the counter shaft to brace the top of the side plate to the frame. Later I fabbed mounts and connected the side plates to the back of the foot pegs on my WR450. That work probably tripled the time I got our of my bearings. It also gave you a more solid riding feel, eliminated the hinged in the middle feel you get on hard pack trails at times.
I just changed out all the double bearing in my TS kit, all bad, the double bearing setup actually puts more stress on the bearings than the old single bearing cups, just fewer complaints because a failed bearing has a poor but still operating one beside it that allows you to get home. Pulled a ts apart last week, one bearing in the double cup just fell out in pieces, broken race, side stress all the way.
