I found that the STMs worked great on the 800 engine and as said above, no real gains in performance because the 800 has a good bottom end stock. On the M1000, however, it is a different story. The STMs really helped the bottom end out. I fought bottom end blubber or roughness a lot on the 1000 engine and found 2 solutions......STM valves or a Powercommander fuel controller. The PC has great resolution and allows the fine tuning needed to clean up the bottom end and get that SNAP! I could clean up the bottom with the BDX valves or stock valves as well as the STM.
If you get the STM valves, make sure to get the new version as I have seen several of the bellows/valve stems come apart.
