Can You swap the gears in a BDX diamond drive (2008).If you want to gear up.Example 58/62 to a 62/58 Or does if require all new gears.
Thanks for your help.
you need new gears. One gear is part of the input shaft and the other gear connects to the planetary assembly. They are completely different.
