BDX 2 Wheel Kit??
I looked on the BDX website and they say if this kit is going on a 141" or a XFire (09 XFire SP is what I have) then either it require shorter adjuster bolts and/or different size bearings??
Any input from you Pros would be greatly appreciated.
If you dont use shorter adjuster bolts the rear scissor will hit the bolts when the suspension is compressed with the shorter skid. Just put it all together with the track adjusted measure how much extra bolt is sticking out then cut the extra off minus a 1/2 inch for future adjustment.
Are you sure they're talking about the 141, not the 136?
I ran the air out of my float to see if it would hit & it's not even close. (09 141)
I have bottomed my suspension on bigger drops & have yet to see a mark on my scissor.
