A
AndyL
First ride today on 800 dragon and it fell flat on its face. Started with bd suggested numbers and it was WAY lean. Sled would back fire bog and die. Looked at every wire to make sure it was connected and made sure ebc was calibrated and set to zero boost.
I started to increase the psi numbers and would very slowly get better. Finally ended up at 97/127/127. 3000 rpm was 0/9/12 and 5000 rpm was 12/12/12.
The sled would rip at wide open throttle with a 12.0-12.6 a/f. Low end was still bad and the middle was still lean at 14-16 a/f. My plugs are reading super lean and decided to bag it before it melted down. I'm no sure where to go from here. I'm running straight 110 at 3000 feet and usually ride 6k but didn't make it that far. I've also tried spraying all the intake points for air leaks and it doesn't affect anything and continues to idle perfect. Any ideas???
