side by side comparing with identical 09 m8 pump gas sleds show's that the pipe makes power. one sled running 7.3 lbs and the turbo pipe, the other at 8.7 lbs. the sled with the pipe still pulled harder even with lower psi. if I had to guess, it would take about 1.5-2 psi more than the piped sled to make them equal, so about 15hp .
I should add, that on my sled wrapping the turbo pipe with header wrap really helped with tuning as this pipe likes to be kept hot
Someone who is smart with turbos walk me through this, but ...
How are you creating more horsepower at a lower level of boost?
It would have to be by dropping the charge temps. If the motor is making more power at 7.3 psi, the temperature has got to be quite a bit lower than the sled making less power at 8.7 psi, all things being equal. EG, the air density is actually greater at 7.3 psig and whatever temperature it takes to make it denser than the air at 8.7 psig at whatever temperature it is coming off the compressor at that pressure.
I can't see any other way that would happen.
So how does adding a pipe gives you an extra 15 horsepower at the crank? What does it do to make the turbo more efficient? I can't see where it would have anything to do with the compressor side.
I'd be very interested as to what it does to make the turbo spool quicker, but I just can't for the life of me see how adding a turbo pipe is going to give you any increase in horsepower.
everything acts as a multiplyer, turbo or na sleds, eg if a pipe is more efficient than the stock one the turboed sled will make that extra power because the pipe is working better at the exact same boost levels. just like proper ported cylinders for boost they will flow more efficient and again make more power at the same boost levels. ita all in the process to make the engine/exhaust flow as efficient as possable which spins the turbo quicker/harder which in turn spins the compressor side just as fast.
Ok, so on the BD turbo pipe ... what is the little peice of aluminum with rivet holes it came with? Where does that go? It looks like its supposed to support the pipe somewhere but I can't see where, they didn't include a schematic with it when they shipped it to me
"The Little Plate Of Aluminum" Is To Support the Exhaust Pipe. It Basically Fits Where the stock Mount site at the Rear Largest Diameter Of the Pipe. You Have To drill Two Or Three Tiny Holes So that you can Rivet The Plate To The Stock Mounting Location. Then Attach The Factory Spring to the Plate.
I Believe it is required Because The Turbo Pipe Sits 1/2" Higher Up then the stock Pipe.
Where the spring holds it down to the bumper on the 90 degree bend? Drill the stock mount out then rivet this one in?
