yes i have a 4th number .. at 3000 the letter is A and the number is 0
5000 the letter is B and number is 4
6700 the letter is C and the number is 4
7800 the letter is D and the number is 1
my question is on the ACEL screen... all numbers are 0 the 4 settings are AL, DR, SN, and AH..
When you are in supertuner mode which you will want out of when your done:
3000 -10 -10 -10 A=0 On Arctic Cats this does nothing
5000 -10 -10 -10 B=4 adjust how Acel fuel is added
6700 -6 -6 -6 C=4 adjust how boost fuel is added (Do Not Adjust This)
7800 0 0 0 D= 9 determines when Acel fuel goes from AL to AH (=4.5 also. Higher numbers cause it to switch at higher numbers, on some boxes if the value is even it disables the temp compensation
8600 0 0 0 E=0 effects temp compensation at idle so if intercooler is heat soaked , it doesnt run to lean
PSI L 11 26 45 OS=20 adjust the initial turn-on amount of fuel. OS can have Effect on slope of fuel amount Aux Inj. give as boost increases. A higher OS w/ corresponding Lower PSI H values can be used to give more fuel @ lower boost levels & relatively less fuel @ higher boost levels then Lower OS #'s with higher PSI H values would give you(this would result in less fuel @ lower boost , more fuel at higher boost. I couldnt wrap my little head around this untill I put it on a graph.
PSI H 11 22 47 CR=26 adjust when your secondary injectors turn on(4.5 unit's per pound of boost,D uses this also) ie: 9 = 2#'s of boost , 23= just over 5#'s. Ill watch my Max Duty Cycle to make sure Im in the high 80's Low 90's and depending on conditions, I do adjust this.
ACEL Al(amount low)=0 DR(duration)0 SN(sensitivity)8 AH(amount high)0. Im not as familiar with this setting as the others so I dont mess with it. I did read somewhere that AL gets canceled and goes to AH when it senses 1/2# boost. When I ran an M7 I did pull fuel out of the AL and set the DR to 25
and it helped with the laggy bottom end, but it also caused a lean stumble just off idle when it was cold. I just pull fuel out to the rpm,s now.
DCEL DR 05 SN 10 This removes boost fuel(but not stock fuel) when suddenly letting off the throttle this helps it from lodading up when going off throttle, then back on.
Hopes this helps,
Don
