Ok here's the deal bought a bd turbo kit off Craigslist with no instructions contacted bd and they don't have them any more and but did give me the m1 instructions which helps i have every thing mounted turbo, intercooler , plumbing for coolant, fuel lines,and figured out wiring for the rectifier and capacitor for the oil pump and the external fuel pump . The turbo is a GT2860RS DISCO POTATO.
The questions that i have are about how the boost reference lines should be ran. I've been torn on the placement of the transducer and where to get boost reference for fuel regulator, ect. I was looking at the tm8 (pump gas) instructions and the transducer was screwed into the airbox so i did that and the same for the fuel reg was going to plumb the blow off valve into the air box also but then it didn't make sense with how a bov works and have stopped the install. i believe this is a BD race gas kit for a m8 .
I believe NOW that the transducer, fuel regulator and blow off valve should get the boost reference from the stock oil injection lines that run into the reed boots if that's the case which i would have to run mix fuel which is fine. should a guy leave the oil injection pump there to oil the main bearings?
I should also note i have v-vorce 3 reeds and spacers idk if i should run them as i found ppl have been having issues with reeds cracking on turbo sleds. a million questions i know, any and i mean any help would be helpful from you guys with turbo sled experience thanx in advance
looking to run 10lb thinking av gas but 110 is also an option mixed with 91 will be running in 10,000 to 12,000 ft elevation also the secondary injectors are in the intake box.
