Bd box numbers bd pg 2010m8
New to the turbo tuning game. So I'm just experimenting with my bd box numbers to try and get my 2010 bd pg turbo dialed in. Ive got my ebc
Set boost at 7psi and +hp boost at 1psi.
Right now it's quite rich in all threw the rpm range, but excessively in the low and high.
Just wondering what bd box numbers people with the same or close to set up are running?
And where abouts in a wide band 02 guage you should try and keep the mixture? My bd instructions say 11ish I beleive, but is that to rich?
Thanks!
Should you see 12.5 all through the rpm range? I dont start to see lower af numbers until I hit the midrange. At idle and on the trail at less than 2/3rds throttle I'll be around 13-14 on the af gauge.
Also if I crawl onto the throttle enough to engage and start moving the af numbers will just keep raising past 15 until I give it a blip of throttle... Can't see that being safe.
Another concern on mine is if your clutch doesn't disengage going down a hill, the rpms will climb and so will my af readings. This normal?
Thanks!
