BCA at haydays?
R
rmscustom
Mike,
Are you going to be with bca at haydays again this year? I want to upgrade to the new trigger on my float pack I got from you last year. Or is something I could do myself? Also what is the cost of doing it?
Thanks, Ryan
BCA will definitely be at Hay Days. Booth #SCS5 contingency row by the big trees and food area. New product will be on display.
They are supposed to be sending trigger pin retrofit kits. I will check on cost and see if they are sending. If you want to upgrade the handle to a cone shaped handle, you will need to send the pack back to BCA. Call customer service at 303-417-1345 and they will take care of you.
Stop by and say hi. I'll also have the new avalanche class schedule.
Mike Duffy
Avalanche1.com
Avalanche education for mountain riders.
Trigger pins are on the order list to be sent to Hay Days. I believe cost is between $10-$20. You can also order the pin directly through BCA. Bring your pack by the booth and hopefully we'll have the pin. I'm flying out, so I can't inspect the order until I get on site.
Mike
Here's what will be at the BCA booth:
New! Float 22 Throttle:The lightest airbag pack in North America. 5.5 pounds with the canister! 22 liters of storage.
New!Float 32.The new standard for bigger packs. Plenty of storage. Completely new design.
Float accessories: Extension strap kit. Scuba refill adaptor. Fire station refill adaptor. Consumer refill kit. Refill center kit.
New!Dozer hoe shovel. Much easier to use than a regular shovel. You pull the snow out of the way instead of lifting it.
New! Stealth Quick-Lock Probes. Easiest and fastest probe to assemble. No loose cable.
BCA Bomber Shovels. The strongest on the market.
Best product, great prices and the best customer service.
Designed for snowmobilers.
