Whats workin good for you guys above 7000feet for clutching with a 275 kit. I have a team secondary I bought of eric last spring for use with the 275 kit
JustBoostIt said:We use 3 different springs, all are over 300 finishing rate. I only use Cutler TM weights so can't comment on anything else. With those it will be around 92-94g and those springs. For those not familiar with th turbo mag weights they run about 5g heavier than the number indicates. ie. stock 85g at 7900 rpm would be an 80g in a TM to be the same rpm. Profile of the arm puts more weight in the tip.
