C
cranktwister
Long story short,05,started misfiring on low end when you stabbed the throttle every so often.Some times when started for first time in morning would start up and run on one cylinder until you gave it gas would start running on two cylinders and run all day except for the occasional misfire as listed above,tail light not working and brake light on dash said brake was on.But machine would still run all day.Now it will only start up and run on one cylinder(mag side)then it will die if you give it throttle or back fire.I have spark to both cyliders.If I put gas in both cylinders it still only runs on mag side.(deep breath)Soo I dove into testing the stator first thing,everything tested good except for the yellow wires,they tested .4 ohms instead of .13 +or-what the manual calls out,I pulled the stator to check for any bad wires,dont see anything wrong except that it smelled burnt and yellow wires at stator are brown where they come out of stator and yellow at the plug.I think I should have done some more testing before I tore all this s#%@# off.Can a ignition coil be bad if it still sparks?Any suggestions?
