I decided to get a gram scale this week and weigh my clutch weights.
Heres what I found
10-62s -> 62.75, 62.71, 62.62 - Not too bad .13 gram variance
10-58s -> 57.76, 57.83, 58.40 - Way to much variance .64 Gram
10-60s -> 60.16, 60.32, 60.65 - Not too good either .49 Gram variance
Well worth the $15 the scale cost.
Now my question is for those that have balanced your clutch weights where are you removing the extra .5 gram of weight from? Are you removing it all from the back side with most of the weight being removed under the weight identification numbers where it jogs out that little bit. Does it matter where on the back side of the weight you remove the extra weight from or just remove it from the same spot on each one?
Heres what I found
