N
Nikolai
ACCOUNT CLOSED
Anyone have issues with Wahl drivers being poorly molded? I swapped out the stock MTX drivers for Wahls. Using 3" pitch drivers with a 150 camo extreme (3" pitch) and the drivers are not working right. I'll try and explain as best as possible. As you rotate the track, the driver lugs slowly creep forward of the track nubs about 1/8" per lug until the driver lugs are soon hitting the backside of the nubs and jump the track. The timing marks are lined up, they rolled fine on the floor, doesn't matter if the track is loose or super tight. Only thing I can think of is the drivers were molded a little bigger than they should be.
