i did check the run out on it and it is good thank god that is the last thing i need to do is put a new crank in that thing. thank all of you for the info. i have been torque ing it to 90 foot lbs
When you put it back together you might want to put some ARP Molylube or something on the threads. A lot of the force used to torque bolts goes to fighting the friction created by the threads. When you use an assembling lube, that force goes towards tightening the bolt instead.
I don't think that I would do that. That friction is the same thing that prevents the bolt from coming loose in the first place.
