Bad injectors
beamslayer
Those that have had bad injectors how did they run ?
What was wrong with the injectors, mechanical or electrical ?
What color injector did you have ?
Believe I had YELLOW. Sled ran ok accelerating or wide open. However, when running with very little load on the motor or slightly decelerating, if felt like and sounded like you had hit the kill button while giving it gas. Kind of a brrrrrrrrrr sound. Does that make sense.
It was actually caused by bad o-rings I believe. Wasn't shutting the injectors off so it was basically getting too much gas there for sounding like I had lost spark under throttle.
Hope that helps.
in the case i had in wot it would pull hard then stumble like it wasn't getting fuel you back off the throttle and get back in it everything was ok,i changed the injectors from the blue to the good yellow then got it reflashed it pulls like a bitch now! i would recommend to change the fuel filter also
I had BLUE injectors in my 11 when it went bad. It would run fine until about 3/4 throttle and then fall on its face like it ran out of gas or hit overrev really bad.
