R
rhino
2001 SUMMIT 800. Mikuni flat slide carbs. I have been playing with the carbs all season with jetting and shims under the needles, so carbs have been on and off a lot. Finally got it dialed in when something new went haywire. It started running extremely rich and fouled the plug on the mag side. Found out hose to DPM was disconnected from the mag side carb. Thought problem was solved. However it was not and I went through another plug on mag side. Fuel consumption was way, way up. Condition got worse and i ran out of plugs,Could hardly keep it running and limped home. I'm thinking it may be a bad float? Is this a symptom of bad floats ? Or running without that hose on for a while does it mess up the MPMN? Or what else could be up?? PTO side plug looked fine.
Thanks for any and all input
