Bad bogging on 14 pro 800
Today I had a very bad bog followed by the check engine light coming on.At one point so bad it would only rev to about 3600 rpm.I had to shut off and restart.The sled only has 500 miles.It did this before around 350 miles and no check engine light.I dumped it off at dealer as this is my 3rd issue with this sled ,my 12 pro never missed a beat.Have there been bad injectors on the 14 .Dealer tried to say all 13 and 14 injectors are the same .Is that true?All stock except MBRP can which I also ran on my 12.I always use Shell gold 91 non ethanol fuel and polaris VES gold.Getting tired of this already any answers would be great.I asume it should have thrown a code when the check engine light came on.I told them too keep it and go ride it till its fixed.They said trade it in and I said yah on a doo,woke them all right up.Even my 09 D800 ran better than this 14 which was built on a friday:face-icon-small-dis
It may be as simple as shortening your throttle cable freeplay by .010" or .020". If not adjusted near zero your sled will bog when you mash the throttle and the check engine light will flash. My 2014 did it today, it took about 20 seconds to take out the freeplay and the problem was solved.
This sounds exactly like the same issue I am having. First time was also at about 350 miles, it was in chest deep power and exact same symptoms. Took to the dealer and they said the tps adjustment was off. Today I was in spring like conditions and blue bird day running slow through the trees and started doing it again. Can you believe that the dealer told me the first time that I could have had to much snow on the hood and wasn't getting enough air?? Wonder what the deal was today since the only way I could get snow on the hood was if I rolled it over.
