During a top end rebuild I discovered the problem many have encountered of the stator connection being melted.
This was on a 2016 Axys, and located in the Velcro bag above the motor on the PTO side (clutch side)
Wanted a good fix,make it watertight and straight forward (goof proof) in the event the connection had to disconnected.
Thought I would share some pictures.
Thanks to Eric (MH) for the idea,and where to purchase.
https://www.snowest.com/forum/showpost.php?p=4131272&postcount=10
I taped the corresponding wires (before cutting) on either side to identify the correct wires when connected back,4 wires. (2 black 2 yellow)
The wires from the stator are a smaller(weird) 16ga vs 14ga- but using the Metri Pack 630 connections it made little difference.
To make it Goof Proof I used one set of each Metri Pack on the same outbound/inbound wires-as to make it a bit straight forward for mating back together.
Re-taped the wires for abrasion prevention, and all went back into the velcro bag,Water tight and a mucho better,positive connection.
Hope this helps to those that are thinking to tackle this before the snow flies.
