Axys Quick Drive gears on Pro-ride
I need to replace my quick drive gears on my 2014 Polaris 800 pro and found a set from a 2018 Axys. Anyone have an idea if new QD gears are compatible? If it is compatible, would the Axys belt or pro belt drive be required? Thanks for your help
The axys gears will work, and with your stock belt. However, you will have "LESS" low end snap. You are essentially gearing it up. You will have worse performance doing this IMO. But if you are just trying to get it on the snow for cheap, then it will work.
Is the Pro RMK and AXYS QD belt different? Different length or Same?
Yes the axys belts are different they have 2 more coges vs the pro belt. Installing axys gears on a pro and using the pro belt the belt has a lot of play in it not nearly as tight as with the stock gears.
