Does the axys motor drop in the pro? And vise versa?
Is the mounting the same.
Forget the pipe , I know that's different.
Totally fits, mounts are in the same spot, the straps are just integrated into case on the new motor
Sent from my SM-G920V using Tapatalk
You would just need electronics and oil pump. If you had a wrecked axys and and pro with a blown motor you could make it workRegardless of it being able to bolt in, you can NOT run the Axys HO engine in a Pro-Ride chassis due to the electronic exhaust valves, electronic oil pump. Even if possible, major & expensive changes would be required to do this.
I think it would be safe to say the 800 CFI 2 could possibly be made to run in the Axys chassis if it will actually bolt in, but you would have to delete the mechanical oil pump, the oil lines from the e-pump would cross over. You could not use the exhaust valve solenoid found on the pro-ride chassis to help control the valves, you would have to plug the ports on the valves. It may be possible to just leave the Axys exhaust valve control motor plugged in but not actually doing anything (cable disconnected), but with out the cable connected from the motor to the valves, it may throw codes. The other would be the fueling requirements could be different because of the different cranks/crank case volume.
