I have a 16 Axys 163, tried setting the clutch alignment this weekend with the AxisCnc tool. Got the alignment close and then starting inspecting my motor mounts and found the front Mag Side to be shot at under 400miles on the sled!!! I am going to replace the mounts but my question is, will this fix the fact that when the alignment was good, I had almost no inward float left on the secondary with the required inner .080 shim. Is there a way to move the motor to the PTO side? Will the mounts fix this? What are your thoughts? Thanks
Ian
Ian
