Axys can on Matrix?
edgey
Anyone that got there 850 matrix have you tried an axys can to see if it fits?
  • 3 Stars
Reactions: TRS
Ill be installing my jaws trail can tmro.
Theres about 1.5 inches clearance between the foam and stock can. Remove the foam, uve got another 3\4 inch. Also theres a angle change on the side pannel and its more than likely put there to keep the pannel ridgid.
I had the SLP competition can for my Axys and talked to SLP if it would work. They said it would work but since the Matryx panels are a little narrower, if you do a lot of sidehilling you are more likely to melt your plastics. The new competition can is a little narrower for this reason.
I installed a axys slp competition can on my matryx. There is more room than other cans i have used in the past. I think with the foam still on the side panel or removing the foam and adding heat tape it will be fine.
