Super excited to be running these arms this year.
They are super lightweight and look amazing, especially in white!
So to fit these on the PRO took a little bit of custom fitting but overall is not bad. The new arms are pushed to the outside tolerance of the old arms and the bushing are much different as well.
I used delrin spacers on the inside and outside of each arm mount. This will hold the arm firm with no slop and should have good longevity as well.
The biggest thing you'll need to do is have the boss machined off of the top of the RMK spindles. Otherwise the AXYS arms will not work. The boss height has been Incorporated into the upper ball joint now, like the trail sleds are.
The thick spacer is ~ OD 31mm, ID 18.15mm, t 10.10mm
the thin spacer is an off the shelf 1/16" think part that fit good enough. It's just there to keep the A-arm/bushing from rubbing directly on the bulkhead.
Machined Spindles:
Delrin Spacers:
Machined Spindles:
Delrin Spacers:
