I would like to try a 36" front end on my axys. Who Has the easiest most reasonably priced complete kit. Also I do not want to add weight.
I just installed the Zbros 36" kit with stock shocks and my skis now hang 1-1/2" lower than before. This doesn't seem like a good geometry change. Who has run them with stock shocks and how did it work?
Are you saying that the front end is now 1-1/2" taller? You may need to add spacers to the front shocks to get the geometry back to stock height. I had to do this on my pro with a 36" kit.
I was going to measure before and after and go from there on my axys when I stick the 36" front end on.
I took measurements from the ski bolt to the floor before and after while the sled was on a stand. I don't like the look of the geometry when the suspension is topped out and how this will affect transfer with the rear suspension. I don't know what kind of shock spacer would help.
I'm just looking for some reassurance from someone who ran this setup. If you buy the kit with the Exit shocks are they shorter?
I took the spring off a shock to get some full travel measurements. There is the same 1-1/2" change at full compression. So the stock and 36" both have aprox 8" of travel, measured at the ski bolt, but the narrower Zbros is shifted down the 1-1/2".
I would still like to hear from someone who has ran this with the stock length shocks.
