What is the big difference and where do you get avgas at? Which one is better, pros and cons and why?
i thought a guy with a turbo already would know this answer?!?
no, just got the turbo, been a two stroke mod guy forever... thats why I am askingi thought a guy with a turbo already would know this answer?!?
Av Gas has very different properties...
I've been diving into this lately too since the pump fuel sux so bad for quality and consistency.
AV Gas has less energy in it (measured in BTU/lb)... AV, about 18,700 BTU/lb, Race gas is about 19,000 for C10... 20,000 for C12
Av Gas has different distillation numbers... the temp at which the fuel vaporizes...AV Gas is MUCH higher in this temp range... which can handicap the throttle response. This higher Vap temp (set at 275°F by FAA specs) keeps the pistons cooler... but they are not interested in any kind of throttle response issues with an airplane... Planes just dont "snap, snap, snap" the throttles like power-sports do. They run at a constant speed and generally not nearly the RPM of a sled motor.
110 VP and 110 Sunoco ("standard") are 107 and 105 MON octane respectively.
Conoco-Phillips did a standard MON test of their 100LL AV gas recently... and it came out as 104 MON.
Lots of people use and swear by AV Gas... but I have to wonder how they are comparing the performance... For me.. It would have to the same conditions, using the same sled with the different gas (drained), same rider.
For a direct replacement for 91 pump fuel... in something that would normally run 91... I don't think 100LL is anywhere near the ideal fuel.
For the high boost strictly hillclimbers that are not relying on the transitional throttle response... That would typically burn 110 Race Gas (105-107 MON) ...The AV Gas at 104 MON might just be the ticket for this WFO type of operation... it would also keep the pistons a bit more cool.
I toasted a boosted rx-1 on avgas. Doing 660' speed runs at 10 pounds boost at 1400' elevation.....not pretty!!! Clutching & A/F was dead nutz on!!!!
