860 rkt 15.1 head my brother in law is an air craft mech. and poilet.he sugget to add oil to the fuel /same mixture each time as theres not alot of lub.in the av. fuel.any info would be great.
Let me address this fallacy that ANY gasoline has more or less LUBE ....
NO gasoline provides any more or less luberication qualitys than another.
LEAD is the only additive in gasoline that is a lubricant, that being said,, ONLY the lead content can be considered.
AVGAS is LOW LEAD,,
pump gas is NO lead
MOST race fuels are higher lead.
In a 2 stroke, the Lead acts ONLY to supress detonation..
adding more oil will LEAN the fuel to air mix and if not jetted up will cause you to deto or go lean..
I don't ean to make anyone sound dumb, Avgas is an excellent easy to use, easy to tune fuel that is NOT a slow burn Low rpm fuel...
It just has been Measured that way by the aircraft industry to show its qualitys for high altitude use..
the higher the altitude you are operating at,, the lower the octane needed for safe operation..
enjoy the savings and smile when someone tells you how avgas is bad,,
tell them your a REBEL !!!!!!!
Gus
burnin avgas for 25 years and loving it !!!
