AV gas ?
W
wilbilly
A friend asked me about running av gas this year . i had to tell him i do not know anything about it . can anyone tell me the pros and cons of av gas
normally people tell you to search, you dont even have to, there is a thread about 5 down from yours thats about the pro's and cons of av vs race gas, search it and you will find a LOT of info, there has to be 20 threads in here alone on it.... here is some reading for ya, hope you got some time to read!
http://www.snowest.com/forum/showthread.php?t=171945
www.snowest.com/forum/showthread.php?p=1902090
www.snowest.com/forum/showthread.php?p=1904485
www.snowest.com/forum/showthread.php?p=1910856
www.snowest.com/forum/showthread.php?p=1899111
www.snowest.com/forum/showthread.php?t=101285
www.snowest.com/forum/showthread.php?t=136808
www.snowest.com/forum/showthread.php?t=124952
www.snowest.com/forum/showthread.php?t=135812
he wants to be able to run up to 20/22 pounds of boost at times . i told him dont go cheap on fuel 100% race fuel c112 or higher
Which kit and what is done to his motor. If the motor is stock myself I would not run more then 16 -17 psi on 100ll. Unless he is running water meth injection I would feel safer running race gas. Again that's just my opinion.
I run 17psi on mcx nytro with head shim on 100ll
yeah, i have played with that calculator more then i can count. its not science, i wont push the limits of octane a spreadsheet showed me, but it gives me a good idea of where i stand for octane needs, not just dumping $$$ into the tank when you dont need it!
