I will try to help him(nate) clarify a bit. The AFR readings bounce all over the place, AEM gauge, it will even go to the dashed lines. Typically on mine if it does that, pig rich. We really had not spent much time on it over the last year, so finally a couple weeks ago I stopped him. Time to get it figured out.. FINALLY. In the past he has just turned it down till it ran clean. The same way Twister taught me to do it.
So, I had him turn it down a quarter turn on the power jets. Couple runs ... 12.9. I have seen them read lean in the past when they were still rich, so lets turn it down another quarter. I have seen them go from 13's to 10-11 readings on a small turn. The next quarter turn went to 13.2. Ok, one more but be careful. It just read leaner. It got rid of the jumping around but was just lean. Appeared that way anyway. Tough to read wash on those Doo's.
He has something else going on too, or a combination of things. It doesn't idle the best so I was messing with it to set the idle. I was trying to get it to calm down and grabbed the choke. When I did, the motor raced. I am guessing he has a air leak somewhere? Also when he grabs the throttle, it sounds like he has some reeds going south. Need to check that.
Oh yeah, not done yet. His FPR, freezes up all the time. I have never seen anything like it. Take a heat gun to it and its fine all day. Leave it sit outside and the next morning its froze and the pressure is through the roof. I don't understand it. Only thing I could figure is he is getting some water in the fuel, but he has been to three different airports. Next would be condensation in the tank. I have seen that when it goes from warm to cold and back again. We tried to turn the FPR down to 3, but the lowest it would go is 3.5-4.
Its a Peak kit, the exhaust comes off the turbo and makes a long S and into the tunnel in front of the chain case. It could be that causing false readings. I have my Poo the same way, and mine reads dead nuts on. Checking wash. Only thing is he has 3" exhaust and mine is 2.5". Not sure if that would make a difference.
The whole thing just needs a little love. We need to go through everything. The kits needs to be upraded/updated in my opinion. I like the simplicity, but it needs a bigger charge tube and bigger turbo.. IMO.
