If the fuel is stored in a cool dry place in a tightly sealed drum, you should be ok. If the container or drum breathes, the "light ends" in the gasoline will evaporate off and it will go stale in no time. If it stayed out of the sun with little temperature flucuations, give it a good shake to re-blend the oil (it will settle out from sitting) and you should be good!
