Attitude box install ??'s
snow_knight
Finally got my attitude box in the mail.. However it never came with any installation.. just a piece of paper that says go to there website.. however there is no installation for a yamaha apex.. or any other yamaha sled for that matter..
Tried to call derrek.. no answer and voice mail box is full so I cant leave him a message... really need to get this put in asap for a trip
Any help?.. pictures?..
thanks rocky
I think its the same as the new pl box.If it is there should be two plug ends and ground. If thats correct above your clutch behind the delta box theres a big grey plug. unplug that and connect your two plugs into that and ground to the delta box and thats it.
K.. ya i was unsure about the white single wire on the side.. however I just found out that is for nitrous and not needed..
There is a hose for boost on the box.. just run a T fitting for that?
K.. I will try that
anybody have a good base start for me.. running 06 mcx 310 rear mount.. 10-12 pounds (currently).. at 6-10k ft. elevation..
thanks rocky
cant run it straight to my intercooler.. going to have to T into where my boost gauge is running too... however the box didnt come with a T.. and I cant find one that will fit the tiny little hose that came on the box... any ideas?
thanks rocky
make sure you make a good ground with the black wire before powering the controller up and yes the white wire is for the nos and for the transducer line I would recommend pluming it in to your inter cooler some where before the throttle body's
