Calling all problem solvers to my rescue
Sled: 2007 M8, Speedwerx Y-Pipe, Pipe, Can. Stock Fuel controller.
Background: First off, my compression in my PTO cylinder is down 10PSI from my MAG side due to stupidity on my part two weeks ago. I ran NOS without bleeding the air out of the fuel line (BOSS NOSS system). Therefore I detonated a lot on a big pull and thought I lost the piston but I was lucky to only be down 10PSI. Result was that I dropped from 7900 RPM to 7500RPM, but it is still good enough to get me through the rest of the season.
I went riding on Saturday and everything was working great, including the NOS.
Later in the day on a big climb I hit the NOS button for a split second (literally less than 1 second) and engine shut down. I pulled the pipe and the plugs and things appeared to be normal. I put the plugs back in and the sled ran, but only on one cylinder. I was not getting anything out of my PTO side no matter what I tried.
I got the sled home, checked my compression and nothing had changed from my initial readings before I went riding. I put my plugs back in and my sled fired right up and is running on both cylinders.
Here's the problem solving piece: Running in my garage, with no load on the track, I warm the sled up and run it steadily from idle up to 6800 rpm, and then the sled shuts down. It almost dies but continues to idle, then I can run it back up to about 6800 RPM and the sled dies again. I can hold RMP's in the 5k range, but as soon as I get into the High RPMs range, the sled dies back down to an idle.
Question: Any ideas on why it dies and won't hold anything in the high RPMs?
I'm stumped.
I'm stumped.
