I did not know that you had to select the "auto-revert" function each time you powered the beacon on..........
I always thought it was just default. Guess I should have read the manually more carefully. Anyway just wanted to make others aware if they thought the same as me.
Auto-Revert System
At startup, the user can engage the Tracker’s auto-revert safety
feature by pressing the options button ë while pressing and
turning the on/off switch. With auto-revert engaged, the Tracker
will revert to transmit mode after five minutes in search mode.
If auto-revert is engaged, “Ar” will be shown in the power
display after the diagnostic testing. If auto-revert is not engaged,
“nr” will be displayed.
If auto-revert has been engaged, then after five minutes in
search mode, an alarm will sound for ten seconds and "Ar" will
flash repeatedly in the distance indicator. To remain in search
mode, press the search/transmit button or the options button
at any time during the ten-second alarm period. If ten seconds
elapses, “tr” will appear and the Tracker will revert to transmit
mode.
If auto-revert is not engaged, the Tracker will sound a short
alarm every ten minutes to remind the user that he or she is in
search mode.
Auto-Revert System
mode.
search mode.
