2018 SKS weight is 443 lbs, the assault is 418 where is the difference of 25 lbs coming from?
From what I can see you have the idler wheels in the back of the SKS (estimate 10 lbs, if any one has the actual weight please chime in), SKS aluminum over structure (estimate 2 lbs difference), both have clicker shocks (assault has needle shocks with bigger shaft so they should be heavier), Assault A-arms should be heavier, both have the chain case, they have different tracks but I would think the Peak track on the assault would be heavier than the 2.4 on the SKS. The only other difference is the front cooler, does the cooler really add 13 plus lbs?
