Hey Guys,
I have an 09 Assault with SLP twins, Carl's cylinder & case porting, Carls ECU tune, 50/50 cut on the head for 2000 feet. I run a Camo extreme 2.5 track with stock gearing. Pulling 74G weights to 8350, with lime green primary spring, 64/42 helix and stock secondary spring as per carls recomendations, although I wound up 6g heavier on the weights than they suggested. I did ask them to go hog wild on the porting and running a shorter track than most.
I max this thing out on the flat in about 500 feet, 85-90 MPH indicated and thats it, right where its geared to be. I have a different set of gears to let me max out at around 105MPH. I only go to the mountains once or twice a year and can swap back and forth if I have to. Basically going from 2.05 gearing to 1.70, more like an older RMK in terms of top end speed.
Thoughts, experiences, suggestions????
Thanks,
Steve
Thanks,
Steve
