Assault A-arm kit
Hello. I bought myself a new Assault this year, and so far Im very happy with it.
I bought the Assault instead of the Pro because my riding style is very variable. I like to jump, drop and ride between the trees.
But since all my friends drives Pro RMKs, we ride alot in the trees.
Therefore im looking for slimmer A-arms, so the sled will be easier to navigate in between the trees.
Does anybody know of a good A-arm kit, around 36"-38", that doesnt require me to buy new shocks? Ive seen alot of kits for the Pro RMK, but Im not sure what modifications I have to do to make them fit my Assault?
Hope someone can give me some input to this. And please provide links to the kits you recommend.
And while Im here, I have another question. I have some SLP powder pro skis, for my Rev MXZ. Does anyone know what modifications have to be done to make these fit my Assault? Or are they bolt on?
Thanks in advance. All feedback is appreciated.
I have the 39'' standard stock Pro width stance but would require a shock length change whether by shimming or buy new. To my knowledge you wont be able to change your stance without a shock modification with any brand. Also keep in mind you would have to shorten tie rods, very easy to do. As for the skies, they should be a direct bolt on, but the rubber saddle will need changed. www.alternativeimpact.com Thanks.
Dan
Haukland, are you in Scandinavia?
If so, there is a kit to make the Assault the same with as the Pro Rmks, with stock Assault shocks, but I have only seen it here in Sweden....
Hey. Yes, Im in scandinavia. I live in Norway, and ride snowmobiles in Sweden. Do you have a link to the kit?
Thank you guys for the replys.
my local prolaris mechanic said that there is no reason to shim the shocks, you can pull back the springs if you wanted it to sit lower, thats all i plan on doing.
Dan
Where can I the rubber saddles for the ski-mount?
Thanks for the reply.
pretty sure SLP has the rubber saddle for different makes of spindles. Maybe call them and be sure they are different than what you have or need. Thanks!
Dan
Ive decided to go for the Zbroz 36" kit, and buy completely new shocks. Can anyone recommend some good shocks to go with these A-arms? I would like to buy the A-arm kit and shocks from the same webshop if possible.
Thanks in advance.
Raptors would be a great choice, Boston Racing probably has all this in stock....
BTW, why did you not go for the A-arms I linked you?
