K Klutch Member Premium Member Feb 7, 2018 #1 Installing a Aro 137 on my 2018 KTM 350 xc-f. Using their TSS kit. When I cycle the suspension, before the TSS shock can bottom out, the bottom of the air box contacts the sub frame of the timbersled?? Anyone else have this issue? Thx.
P powdermuncher Free Member Feb 7, 2018 #2 TSS is not supposed to bottom out crank up the pressure. At about 240 pounds with pack and gear I run 350 psi. Do not consider the TSS to be a primary suspension. Less movement is better. Just enough to have some give in the hard hits is all you want.
K Klutch Member Premium Member Feb 8, 2018 #3 What did you use for a gauge, the pump only goes to 300. I'd be close in weight to you.
