G
GaNiBiS
Hey guys.
2014 Yz450 with an 18 ARO 137 kit. I replaced the stock front chain slider as it was broken and worn right through during the preseason checkover.
With the kit back installed I'm starting to notice some things. The replacement slider after a 5 mile test ride is wearing quite severely. Almost like the center rib of it is off by about 1/8" to the center of the chain.
This got me looking into seeing if the kit spacers were installed correctly. They look perfect. Can't see any part numbers to confirm but I cant see them fitting any other way. I also took some measurements and the kit doesn't seem to be quite centered on the bike. But are my measurements point centered on the frame???
Can someone with a similar set up check their measurements to mine and let me know if I have something potentially installed incorrectly. Left side from the outside of the wishbone mount to the outside of the kit side panel is 3 5/8". Right side is 4 1/8"
Thanks in advance
Sent from my LM-G900 using Tapatalk
Thanks in advance
