Are there any issues with the Pro Ride Defrost Bag ?
MDEVO
Chic Chocs Addicts
Anyone install on a Switch Assault?
If so any problems?
My dealer recieved info from Polaris that states the bags do not fit every pro ride model.
Why not I asked, but they did not know....:face-icon-small-dis
My friend has one installed on his Switch Adventure and I see no problem with that install, but I think maybe the only reason it would not fit is due to the Pro Taper Bars on the SBA contacting the bag while turning hard in either direction????
Appreciate if anyone could confirm?
Thanks.
I am installing my riser and bars, so I'm sure it's not an issue for me, but wanted to clarify this information for others.
For those interested here is the info (an update to the catalog):
Just finished mounting this bag on my 13 ProRMK, the instructions were for a 12 with the alum overstructure.
I tucked the end of the support rod in behind a wiring clip on the far side like mentioned above. You have to be a little creative with the hood / batt wiring but it works. And also like mentioned above the forward hook on the bag will go in a hole on the inboard side of the CF tube.
Danbot... I think he is talking about the bag that re-mounts the gauge behind the dash and allows for stashing your gloves and goggles in a bag on the dash.
Part number 2879090
Part number 2879090
MH is correct.
PRO-RIDE™ DEFROST BAG
Also, thanks for the clarification......
Defrost Bag
New switch hole is round and does not have straight sides to lock in switch body so unit turns when using electric start.
Stock switch hole on dash is correct
Really? That is ridiculous.....kinda stupid spot for it anway tho...
NOTE:
I recieved intel and pics from HCS that prove there are no issues when rotating bars in either direction on the SBA (even with hand gaurds installed).....so SBA owners can go ahead and buy one!
:bounce:
