Are Mikuni TPS's interchangable?
I
IQRTurbo
Pulled my airbox off my PRO Turbo tonight to turn up my oil pump and cracked the TPS when the airbox came poping loose after the o-rings finally let go (along with some knuckle skin.) Wondering if a TPS from the mikuni rack carbs form the 2003-2005 era are the same or interchangable with the version on the '11 PRO. They look identical and had thought I would just ohms test the two full closed and full open to check for myself but the broken one does not read anymore.
Anyone know for sure? I have this other one sitting here and will never use it on a carb again anyway. Thanks in advance.
I realize I will have to calibrate either one after installing it.
Yes, it will work a TPS.. is a TPS...
Yes, Just make sure to Calibrate it.. !! :)
I love finding the part in you need right at home!
But... The Plug.. in is different!!
Too much dinking around there....
You could change the plug.. IMO, just go get the right part
3131591#
I put 2004 arctic cat TPS in my 06 900 and it worked great. If it fits and plugs in I am sure it will work.
I was hopefully looking for a higher quality, plug and play, replacement TPS from Mikuni.
Last week I did a little test on the bench. I checked two Polaris CFI2 TPS. One new and one used and compared them to a new BRP PTEK TPS. I mounted them on a set of PRO throttle bodies and set to PI base setting. I checked the ohms and voltage at 68* room temp. PI and BRP are not the same, ohm scale is different and so is the voltage scale. I don' think I would be swapping applications without making sure the component shares the same parameters or values.
