Are flex glides nessicary?
m1kflyingtiger
Pretty much as the title says. Are flex glides something you need in an enclosed or does it work just as good to miter the normal ski glides?
My preference is indoor / outdoor carpet, but you probably already read that on here. If it is just you and the same sleds all the time I could see going with the guides. I see them as a trip hazard and inconvenience personally, but none of my sleds are the same width so one side or the other would be running a muck. With the carpet you just steer where you want to go. My two cents
I had missed that, and probably would have looked into it, but I've already bought the low profile glides, was just curious about the corners. I currently have 3 pro's (one for sale) and most of my riding buddies ride pro's as well. There is an m and nytro in the mix, but ill set it up mainly for my sleds.
Mitering them should work every bit as good as the pre-made ones. You can either do the math for the desired radius or just wing it. A little light heat with a propane torch will debur and round the edges if so desired.
