I say yes, aluminum is the way to go. Lighter weight, rust resistant, looks better, easy to work with when modifying.
Last time I checked not to many people have the ability to weld aluminum, so your statment about eaisier to modify has no logic.
You also have to remember aluminum will not rust but it will corrode away.
As far as looks I have a steel framed trailer, but looks just like the aluminum one. You do not see the frame.
I would go with steel becasue it is stronger per pound, easier to repair becasue anyone can repair steel with a regular welder, and i believe you will not see a difference in fuel mileage. Fuel mileage is more related to wind resistance than the extra 500 LBS of a steel trailer.
But if you want to spend the extra 2000 dollars on the same trailer that is up to you. I would personaly rather save that money and put it toward the sleds or accesories for the trailer. That and you can buy a whole lot of fuel for 2000 dollars if you are thinking you will save on fuel with the aluminum trailer.
A well built aluminum trailer won't be much lighter than a steel equivelant (and it shouldn't)
At 15yrs old the aluminum trailer can pass for barely broke in. It just lasts forever.
Welding aluminum is straight forward with the proper equipment.
We run 30' stock trailers and do all the repairs
