Arctic Cat ZR 800 engine partout
Parting out a full 2001 arctic cat ZR 800 3500 miles, bad crank bearing.
The engine is torn down and the chassis is being stripped, everything is available Please send a PM with what you need.
Y pipe $25
Exhaust pipe $100
Crank – needs bearing and rod SOLD
Oil pump $25
CDI unit $100
Exhaust valve regulator $50
Ignition coil $75
Stator, Flywheel, base plate, Ignition timing sensor $250 for all of it!!!
Brake Rotor $15
Reeds $100 for 2
Reed Boots $40 each, $75 for 2
Wiring harness $20
Voltage regulator $15
Air Box with lid $20
tool kit $10
Black stock skid plate $15
Spindles $10 each
Steering post $15
wilwood brake reservoir and lever $50
Left belly pan halves $30 each
