for sale is highly modified 99 cat powder special. after market tunnel, 8" big wheel kit, 10 tooth anti ratchet drivers. 163x2.5x3.0 track off of a 2010 cat. power mad 8" bar riser with pivot mount. the motor is a 950 psi genesis freshly rebuilt by bruce at psi. it less than 2 hours on the complete rebuild from top to bottom. i have the reciepts. fox shocks. the chaincase is rolled as far as possible, geared down for climbing. twin egt gauges and a single aftermarket temp gauge. twin psi pipes and silencers, 46mm psi big air carbs with twin filters. dial a dome head. polaris team roller primary clutch, factory secondary clutch.
What is the sled worth?????
