Arctic Cat m7 Turbo kit 3000
Aero 53 series turbo. I had turbo performance check turbo! everythinhd looks new!
this kit comes with everything you need from clutching to 4 window display egt and rpm gauge. boost and fuel gauges ect....
$3,000
Will work for other m series sleds
Were you running race gas or pump?
How much boost?
Does it come with fuel controller?
Did you use stock fuel pump with this setup?
Thanks.
can i run this turbo with ported jugs and an RKT head? if not where can I find stock jugs? or does somebody want to trade me my ported jugs for their stock jugs?
U could probably get away with running the ported cylinders but not the head! U Need stock head! I can get u a head and jugs if needed. If your timing has been advanced u will need to change that back as well!
how many miles were ran on this kit, how old is it and what kind of fuel controller are you using and where are you located?
