Arctic Cat M-7 Primary
Trying to find information on a performance modification for the primary clutch on my M-7. Does anyone know the specs used for machining out the spring cup on the spider? I've done everything else possible on both clutches. Just looking for that little bit extra. ?
Go to ACE Hardware and pick up at set of nylon washers for spring to contact on each end of clutch. Used this method for 10 years with no problems.
Sounds like a really good idea. In reality, this would allow the spring to basically turn while being loaded and unloaded with less restriction. Do you notice big improvements in clutch performance?
